answer for yxwsd:
[center]legg-calvé-perthes syndrome[/center]
legg-calvé-perthes syndrome is a degenerative disease of the hip joint, where a loss of bone mass leads to some degree of collapse of the hip joint, that is, to deformity of the ball of the femur and the surface of the hip socket. the disease is typically found in young children and small dogs, and it can lead to osteoarthritis in adults.
it is the idiopathic avascular osteonecrosis of the capital femoral epiphysis of the femoral head. it is caused by an interruption to the blood supply of the head of the femur close to the hip joint. it is equivalent to adult avascular necrosis.
it is also known as perthes disease, ischemic necrosis of the hip, coxa plana, osteochondritis and avascular necrosis of the femoral head, or legg-perthes disease or legg-calve-perthes disease (lcpd).
cause
the direct cause is a reduction in blood flow to the joint, though what causes this is unknown. it is thought that the artery of the ligamentum teres femoris closes too early, not allowing time for the medial circumflex femoral artery to take over. genetics does not appear to be a determining factor, though it may be involved. when the disease is genetic in origin, it typically runs along the male line. some evidence suggests that parental smoking may be a factor, though this is not yet proven, or more recently that a deficiency of some blood factors used to disperse blood clots may lead to blockages in the vessels supplying the joint, but that, too, has not been proven.
signs and symptoms
symptoms are hip or groin pain, exacerbated by hip/leg movement. there is a reduced range of motion at the hip joint and a painful or antalgic gait. there may be atrophy of thigh muscles from disuse and an inequality of leg length. in some cases, some activity can cause severe irritation or inflammation of the damaged area including standing, walking, running, kneeling, or stooping repeatedly for an extended period of time.
the first signs are complaints of soreness from the child, which are often dismissed as growing pains, and limping or other guarding of the joint, particularly when tired. the pain is usually in the hip, though can also be felt in the knee (so-called ';referred pain';). in some cases, pain is felt in the unaffected hip and leg. this is due to the child favoring the injured side and placing the majority of the weight on the \"good\" leg. it is predominantly a disease of boys (around 4 in 5 cases). whereas perthes is generally diagnosed between 5 and 12 years of age, it has been diagnosed in children as young as infants. typically the disease is only seen in one hip, bilateral perthes is seen in about 8-10% of children diagnosed.
diagnosis
x-rays of the hip joint are absolutely necessary. a bone scan may be useful in helping determine the extent of the avascular changes. a hip aspiration may be performed if there is suspicion of a septic arthritis.
diagnosis is made predominantly by x-ray study, together with physical examination (mris have also been found useful for judging the extent of the deformity). sufferers typically have limited range of motion in their hip, particularly when rotating the joint.
treatment
the goal of treatment is to avoid severe degenerative arthritis. orthopedic assessment is crucial. younger children have a better prognosis than older children. currently, there are studies conducted on bisphosphonates[2] for treatment of perthes. analgesic medication may be given as necessary.
treatment has traditionally centered on removing pressure from the joint until the disease has run its course. options have included bed rest and traction (to separate the femur from the pelvis and reduce wear), often for several months or even years. plaster casts were also popular, again |
