查看: 1167|回复: 2
[病理诊断] CT49817:腮腺混合瘤
发表于 2015-1-28 22:22 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
手术名称:右腮腺瘤切除术。
术中所见:肿物位于腮腺浅叶,大小约1*1*1cm,边界清,质中,固定,有完整包膜,与周围组织粘连,血运一般。
免疫组化:3:CK(PAN)(++) CK7(++) Ki-67(<1%+) P53(-) P63(少数+) S-100(+) Vimentin(+)
病理诊断:(右)腮腺肿物:镜下形态结合免疫组化检查,意见为涎腺混合瘤
【点击阅片】
001042934 (148.66 KB, 下载次数: 36)
发表于 2015-1-29 09:57 | 只看该作者
病理诊断:(右)腮腺肿物:镜下形态结合免疫组化检查,意见为涎腺混合瘤。
发表于 2015-2-10 16:08 | 只看该作者
Motorists claim traffic queues are 'worse than ever'
, I've sat there and the lights have changed http://www.freewebsite-service.com/coleng/Blog.php and i've not moved
The bus lane that even some buses do not use helps to hold up any traffic planning to turn right down rodwell avenue and hinders.
Emergency vehicles shopping for come through up rodwell road: "Mum jeanette a'court considered that, it's so stuffed between 4pm and 6pm.
"There's a constant drone of traffic in the lounge of an evening and have the ability to open the windows,
I dread to think what it will likely be like in the summer.
Shelly stevens said she was recently in a near miss with a car that tried to turn around on her driveway because the traffic was so bad: "She asserted, because of the traffic lights were put in.
"It's horrific out there.Someone http://www.xtrablog.com/liaoyangs/ inverted into my legs,
It used to only be bad at teatime and now it's all the time and especially most morning, the mum of two added that she takes a 'short cut' by simply cross road, wyke avenue, faircross method, everest http://liaoyangsss.mex.tl vehicle.
Chickerell road and marsh road to access asda because it cuts down on journeyguesthouse owners also say they are fed up with the congestion, robbie feltham, proprietor of the kingswood guesthouse in rodwell road.
Said his business has been greatly affected: "He was quoted saying.My whole winter trade was totally demolished, without any shadow of a doubt.Passing trade has dropped off impressively,
Everyone thinks weymouth moved mad, bridget boudier, who owns trelawney in old castle road: "Claimed.In my opinion, it's a total mess,
All the homeowners are using cross road to get anywhere, sailor jones zajac, a person in the austrian national team.
"Has returned to weymouth to train for the sail for gold regatta and thinks the traffic incident has worsened, the traffic lighting is worse http://liaoyangs.muzy.com/ than the roundabout was.
"He http://liaoyangs.muzy.com/ explained,
At the moment it's worse but hopefully the infrastructure will be better a few after the olympics"The traffic lights are there so your"Top dogs.
Can be given a clear run to portland within olympics.
Complaining about them will achieve nothing because the olympics takes precedence over all other things to consider.
The only effort for local residents will be footing the bill after the white elephant is over"The traffic lights are there so the"Exclusive.
Can be given a clear run to portland inside olympics.Complaining about them will achieve nothing because the olympics takes precedence over all other choices, once all the lights have been installed it will work as one and the lights will change pc traffic.At that time it doesn't.I also drive through the traffic lights on boot hill and they are a nightmare but when the work is finished at the stop it should help because cars at the bottom of boot hill wanting to turn right can go straight on instead.
But i think they should change the lights on boot hill to let increased traffic through until the work is finished.It's a smart traffic system and you will never complain until it's all finished, once all the lights have been installed it will work as one and the lights will change with regards to the traffic.At this time it doesn't.I also drive through the traffic lights on boot hill and they are a nightmare but when the work is finished at the place it should help because cars at the bottom of boot hill wanting to turn right can go straight on instead.Unpassable once in a while
