查看: 1494|回复: 3
给大家一套英文考试题【手和腕】
发表于 2004-10-12 04:35 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
1.        the ring finger is the _____ digit?
        a)        first
        b)        fourth
        c)        second
        d)        fifth
        2.        where is the cr location for all lateral hand projections?
        a)        perpendicular to the third mcp joint
        b)        parallel to the second pip joint
        c)        perpendicular to the second mcp joint
        d)        parallel to the third dip joint
        3.        all 22 bones of the hand should be included when doing a pa projection of the hand.
        a)        true
        b)        false
        4.        the thumb is in a lateral position when doing a pa hand projection.
        a)        true
        b)        false
        5.        the hand should be made into a fist for what projection?
        a)        pa hand
        b)        lateral hand
        c)        pa wrist
        d)        none of the above
        6.        the proximal wrist bones are: pisiform, triquetrium, lunate and capitate.
        a)        true
        b)        false
        7.        the _____ is the smallest wrist bone.
        a)        lunate
        b)        hamate
        c)        pisiform
        d)        scaphoid
        8.        rotatation of the forearm so the palm faces down is called:
        a)        hyperflexion
        b)        inversion
        c)        supination
        d)        pronation
        9.        the hand is made up of _____ bones?
        a)        25
        b)        27
        c)        33
        d)        22
        10.        the wrist bones are known as:
        a)        carpals
        b)        tarsals
        c)        metatarsals
        d)        phalanges
        11.        the base of the metacarpal is proximal to the head.
        a)        true
        b)        false
        12.        you do not need to include the wrist bones on a pa hand projection.
        a)        true
        b)        false
        13.        what bone is the focus of the pa ulnar deviation projection of the wrist?
        a)        lunate
        b)        scaphoid
        c)        pisiform
        d)        capitate
        14.        the thumb is known as the first digit.
        a)        true
        b)        false
        15.        a 40 degree tube angle is needed for the pa ulnar deviation projection of the wrist.
        a)        true
        b)        false
        16.        the wrist is made up of _____ bones?
        a)        6
        b)        22
        c)        8
        d)        10
        17.        the proximal wrist bones include the:
        a)        lunate
        b)        capitate
        c)        trapazoid
        d)        trapezium
        18.        the cr for a pa wrist projection should be placed at the base of the third metacarpal.
        a)        true
        b)        false
        19.        where is the cr location for an pa oblique hand projection?
        b)        parallel to the third pip joint
        c)        perpendicular to the third mcp joint
        20.        you need place a side marker on all wrist projections even if done on the same film.
        a)        true
        b)        false
answer key -- hand and wrist
        1.        b        fourth
        2.        c        perpendicular to the second mcp joint
        3.        b        false
        4.        b        false
        5.        c        pa wrist
        6.        b        false
        7.        c        pisiform
        8.        d        pronation
        9.        b        27
        10.        a        carpals
        11.        a        true
        12.        b        false
        13.        b        scaphoid
        14.        a        true
        15.        b        false
        16.        c        8
        17.        a        lunate
        18.        b        false
        19.        a        perpendicular to the third mcp joint
        20.        b        false
发表于 2004-10-12 05:05 | 只看该作者
发表于 2004-10-14 05:52 | 只看该作者
发表于 2004-10-15 22:11 | 只看该作者
你好伟大
