查看: 2196|回复: 12
CL0011:[转帖]Operable Pancreatic Neoplasm
发表于 2004-4-21 03:27 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
clinical history: elderly woman presented with severe jaundice and change
in the color of her stool.
findings: three ct images are provided over the upper abdomen.
the first scan shows the dilatation of the intrahepatic biliary system
and a fluid mass in the left lobe of the liver.
the second scan shows the dilatated common duct continuing toward the pancreas.
the proximal nect of the gallbladder is seen in the porta hepatis.
the third scan shows a dilated gallbladder and a normal appearing common duct.
ercp shows opacification of the common duct and the pancreatic duct,
with focal narrowing in both.
diagnosis: operable pancreatic neoplasm. infiltrating neoplasm involving the common bile duct and pancreatic duct. simple hepatic cyst.
discussion: dilatation of the ductal system can be appreciated by noting the low density branching structure within the liver, which converges in the porta hepatis to form the common bile duct. the common bile duct dilatation ends in the porta, above the head of the pancreas indicating that the problem is confined to the duct. the abrupt ending infers neoplasm because inflammation typically shows sequentially smaller concentric rings as the duct tapers distally. ercp shows narrowing of the common duct and pancreatic duct. concurrent narrowing of both makes infiltrating neoplasm most likely. ct scan indicates the patient is opearable, but an angiogram was performed to document operability because of the anticipated whipple procedure.
[本贴已被 翁志蓬 于 2004-4-21 23:33:12 修改过]
[本贴已被 翁志蓬 于 2004-4-22 0:04:04 修改过]
[本贴已被 翁志蓬 于 2005-10-9 1:35:09 修改过]
发表于 2004-4-22 04:47 | 只看该作者
谁来翻译成中文,这样倒是学习英文的好方法.
发表于 2004-5-2 01:51 | 只看该作者
[灌水]
中国人的地方用啥英语,这地方有几个老外啊?
我们知道你会英语,反正我们听不懂
[本贴已被 qiuazhang 于 2004-5-2 11:36:23 修改过]
 楼主| 发表于 2004-5-3 02:17 | 只看该作者
看到好东西转给大家而已,翻译过来太麻烦了,
我得写到什么时候呀!
发表于 2006-3-30 20:46 | 只看该作者
一知半解!!
发表于 2006-4-23 01:24 | 只看该作者
先天性胆管囊肿?
发表于 2006-8-18 05:11 | 只看该作者
看不懂?
发表于 2006-11-6 04:51 | 只看该作者
先天性胆管囊肿
发表于 2007-2-28 23:30 | 只看该作者
病历: 年老的女人以严格的黄疸和变化呈现了
在她的凳子的颜色中。
调查结果: 三个 ct 图像在上面的腹部之上被提供。
第一扫描表演 intrahepatic 的 dilatation 胆汁的系统
而且在肝脏的左边圆形突出部中的流动块。
第二扫描表演 dilatated 通常的管向胰脏继续。
胆囊的近位 nect 在 porta hepatis 被见到。
第三扫描表演一个被扩大的胆囊和常态出现通常的管。
ercp 表示通常管和那胰脏的管不透明,
藉由焦点的变窄在两者里面。
诊断: 可实施的胰脏肿瘤。 浸润包括通常的胆汁管和胰脏的管的肿瘤。 简单的肝脏包囊。
讨论: ductal 系统的 dilatation 能被藉由在肝脏里面注意低的密度分岐结构感激,这在 porta hepatis 中聚合形成通常的胆汁管。 在指出问题盘据管的胰脏的头上面,通常的胆汁管 dilatation 在 porta 中结束。 因为怒火典型地末梢部地表示如管小腊烛的继续比较小的同中心的戒指,所以突然的终止推论出肿瘤。 ercp 表示通常管和胰脏的管变窄。 两者的并发事件变窄制造很有可能浸润肿瘤。 ct 扫描指出病人是 opearable ,但是因为被预期的 whipple 程序 angiogram 被运行证明可操作性。
发表于 2007-6-30 00:52 | 只看该作者
中国话都说不利索.还玩洋文,造作!
